-deleted-
10 years, 11 months ago.
Yaw Pitch Roll outputs
Is it possible to add these outputs to the library?
How do you set a threshold or limit for say roll within the BN055 that triggers an interrupt output from the BN055 so that the mbed does not have to poll data?
I found this: http://developer.mbed.org/questions/5983/How-to-Get-PitchRollYaw-from-Quaternion/
and http://developer.mbed.org/users/kenjiArai/notebook/bno055---orientation-sensor/
Hi Ed!
Did you have any luck with interrupts? I'm trying and trying and trying but they don't work :(
posted by J J 08 May 2015
Hi Ed,
Thanks your interest for my library.
BNO055 already has a function, "Euler Angles output" and you can get th data from the library without any modification.
You don't need any additional calculation because BNO055 includes ARM Coretex-M0+ inside of the chip and all of normaizations are done by the chip.
I have NOT implemented an interrupt handler in the library.
In the documents (see below link), following interrupts are available in the chip.
https://www.bosch-sensortec.com/en/homepage/products_3/sensor_hubs/iot_solutions/bno055_1/bno055_4
  1. Accelerometer Slow/No Motion Interrupt
  2. Accelerometer Any Motion Interrupt
  3. Accelerometer High G Interrupt
  4. Gyroscope High Rate Interrupt
  5. Gyroscope Any Motion Interrupt
Chip uses raw Acc or Gyro data for an interrupt generating factor but not by calculated data.
posted by -deleted- 25 Apr 2015
Thank you Kenji, this will help me.
