8 years, 4 months ago.
export to sw4
Exporting Nucleo_blink_led from mbed to sw4st32 ends with error: Nucleo_blink_led.zip_expanded/Nucleo_blink_ledtmp/tmp3ryfKY/mbed_config.h: No such file or Directory when building.
The problem din not exist 3 month ago.
Need help.
6 years, 10 months ago.
Hello I have a question related to the code which can not be written today with mbed, for example, the code related to HR TIMERS of STM32F334.
What is the recommended method for rapid prototyping including code done with mbed and code written with another IDE? Is it to write and test the code with mbed when it can be done with mbed, then export it to the another IDE, test on it and complete the code on it?
Regards
Jorg,
Can you please provide a link to the example code you are trying to export? I would like to try and duplicate your problem so we can try to solve it. Also, please email this issue to support@mbed.com so we can follow up in our support channel.
-Austin
Hello Austin, thanks for your answer. Here is the link: https://www.dropbox.com/sh/wlihadehppyacwg/AACPFnqMrWYFjQKNWk-xGT3Ta?dl=0 Nucleo_blink_led.zip
posted by Jörg Sturm 01 Nov 2017
Nucleo_blink_led.zip is the export form mbed image1 shows the error after first build all. Then in properties I changed the path for mbed_config.h image2 shows the error after the second build all. Thanks a lot Jörg
