8 years, 6 months ago.
What about the board "uBlox C030-N211 IoT Starter Kit"?
Hi, I'm new here since monday. The last days I tried to program the evaluation board "uBlox C030-N211 IoT Starter Kit" . I'm not so familar with all functions of the mbed-compiler, but the last days it was able to choose the board C030. If I startet the compiler today there was a blank compiler website without all programms in my workspace and the platform was "Default". I tried to choose to my board but I can't find it anymore. A saved link was my anchor to come back to my workspace, the platform is also now correct again "C030". Yesterday I noticed also, that some programs not to be exported - the message was "An error occcured during export. Please contact the support" but I thought it was just my mistake.
My Question: What about the board "uBlox C030-N211 IoT Starter Kit"?
Thanks for answering. Best Regards, Frank
Frank,
Please try clearing your cache / cookies in your browser. Then try logging out and back into the website.
What exporter are you trying to export for?
-Austin
Hi Austin, Thanks for your answer but it seems like, it solved not the issue. I’m working with a Mac and Safari and I cleared the cache like you described. By next login I saw my programs in the compiler workplace, but compiling doesn’t work. So I logged out and startet in the virtual machine (Win 10) the website and also the compiler. OK, it works fine. And after this, it works in the Mac-environment too. Don’t know, what happend. I can also create a new program with the C030 board. So the system works at the moment. Probably I'll be back, if the system don't work again. Unfortunately I can not insert screenshots showing the wrong behavior.
Next part: With the program "example-reading-imei-imsi" today I tried all possibilities to export, without success.
And the open question: I can not find the board C030 in the board overview and so I’m afraid, the support will ending soon. Can you tell me some things about this?
Thanks for your efforts Frank
posted by 01 Nov 20178 years, 6 months ago.
Frank,
For reference here is a link to the wiki syntax for mbed.org so you can post pictures next time : https://os.mbed.com/cookbook/Wiki-Syntax
Can you provide the following:
- The version of OSX you are using
- The version of Safari
- The URL of the program 'example-reading-imei-imsi'
- The IDE you want to export to
With this information, we should be able to replicate your issue.
We recently saw some downtime with the online compiler, so you probably caught that amidst the other issues. Apologies.
Hi Sarah thanks for the link to posting pictures.
Answers to the question of yours:
- MacOS: Sierra Version 10.12.6 (16G29)
- Safari: Version 11.0.1 (12604.3.5.1.1)
- URL: https://os.mbed.com/compiler/#nav:/example-reading-imei-imsi;
- The IDE we want to export to is not yet determined, we are still searching.
This is the design of the compiler in my safari. I can not close the help, edit or compile the source or changing the folder. I can not close the help, edit or compile the source, or change the folder. Subsequently, the compiler seems to freeze.
Thanks and regards, Frank
posted by 02 Nov 2017
