8 years, 4 months ago.
find a smd led,it called sk6812-4020 LED side. someone know what different between sk6812 and it?
/media/uploads/billyi/sk6812-4020_led_side.pdf
7 years, 10 months ago.
The have use the same ic sk6812,the protocol is the same. SK6812 side 4020 led datasheet is http://www.normandled.com/upload/201804/SK6812%204020%20SIDE%20LED%20Datasheet.pdf
SK6812 5050 Led Datasheet is
http://www.normandled.com/upload/201805/SK6812%205050%20Datasheet.pdf
Ivan,
what is the context here? Are you asking about a specific platform or component? Or are you just looking for hardware to use in a project? If the latter I suggest digikey, element14, farnell, or avnet to source parts from.
-Austin team mbed
8 years ago.
i know it, i saw it at: http://www.led-color.com/upload/201803/SK6812%204020%20SIDE%20LED.pdf it has the same IC with sk6812 smd 5050 rgb led, just side view and different size for a new package./media/uploads/Aliyali/sk6812_side_4020_smd_led.pdf
