8 years, 5 months ago.
X nucleo nfc01a1 code
Hello everbody, I am having some problems in order to find a code to check the x-nucleo nfc01a1 working with the nucleo l432kc, When i try to compile some examples codes i can not find anything which works because every code is made for other stm32 boards. What should i change in the code? When i select as target board l432 kc different errors occurs. I was looking for a simple program to redirect my smarthpone to certain website when approached to the module. Thanks in advance
