7 years, 12 months ago.
How can I use LPUART on NUCLEO_L476RG ?
To use LPUART, I put the below code but I found the log message "Cannot initialize UART". Shall I initialize something before using it ?
DigitalOut led(LED1); Serial lpuart_port0(PC_1, PC_0);
int main() { float meas;
printf("\nAnalogIn example\n\r");
while(1) { meas = analog_value.read(); Converts and read the analog input value (value from 0.0 to 1.0) meas = meas * 3300; Change the value to be in the 0 to 3300 range printf("measure = %.0f mV\n\n", meas); if (meas > 2000) { If the value is greater than 2V then switch the LED on led = 1; } else { led = 0; } wait(0.2); 200 ms } }
