8 years, 5 months ago.
SPI not functioning correctly
I am using the Nucleo board with the nRF24L01P chip library (found here: https://os.mbed.com/cookbook/nRF24L01-wireless-transceiver). If I use two mbed chips, the rf chips talk to each other just fine. When I try the same thing with the nucleo, the default settings are different and the correct tx and rx registers cant be found. I took some screen shots of the spi signals of both mbed and the nucleo and they appear different but I dont know how to fix that. The nrf library seems to instantiate the correct polarity and phase of the SPI but nothing works. I have posted the screen shots and my code below.
/media/uploads/vceyssens3/nucleo_waveform.png
/media/uploads/vceyssens3/mbed_waveform.png
https://os.mbed.com/users/vceyssens3/code/Nucleo_blink_led/
Affordable and flexible platform to ease prototyping using a STM32L031K6T6 microcontroller.
Hey From your report, it's hard to tell whether issue comes from SPI or anywhere else. You'd need to instrument the library and see what fails. I don't have a nRF24L01P to test with. Can you share the first console logs of the working setup and the failing one ?
posted by Laurent Meunier 26 Oct 2017
The first console logs for the working setup: nRF24L01+ Frequency : 2402 MHz nRF24L01+ Output Power: 0 dBm nRF24L01+ Data Rate: 1000 kbps nRF24L01+ TX Address: 0xE7E7E7E7E7 nRF24L01+ RX Address: 0xE7E7E7E7E7
Console Log for failing setup: nRF24L01+ Frequency : 2400 MHz nRF24L01+ Output Power: -18 dBm nRF24L01+ Data Rate: 1000 kbps nRF24L01P: Unknown getTxAddress width value 0
The code throws an error after this last entry because it didnt find the correct TX address
posted by Vincent Ceyssens 29 Oct 2017
