8 years, 6 months ago.
SPI problems with Nucleo 64 STM32f401re
I'm trying to use an SD card library with my STM32f401re Nucleo. I haven't been having any luck (can't mount card). To begin with I wanted to make sure SPI was working properly, so I've used the SPI hello world program, and hooked up a logic analyzer to the pins. The first strange thing is that I see the clock line going at 333kHz. I've tried selecting 1kHz, 100kHz and 1MHz, but I see no change in the SCK frequency. I am aware that PA_5 is also attached to the LED - could this be the problem?
Here's my code (incidentally this is hooked up to an SD card - I don't actually expect to generate the correct response from the SD card, I just wanted to make sure the nucleo was sending what I thought it should be):
<<quote>>
/* mbed Example Program
- Copyright (c) 2006-2014 ARM Limited
- Licensed under the Apache License, Version 2.0 (the "License");
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an "AS IS" BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
- include "mbed.h"
- include "mbed_debug.h"
SPI spi(D11, D12, D13); mosi, miso, sclk DigitalOut cs(D3);
int main() { while(1) { Chip must be deselected cs = 1;
Setup the spi for 8 bit data, high steady state clock, second edge capture, with a 1MHz clock rate spi.format(8,3); spi.frequency(1000);
Select the device by seting chip select low cs = 0;
Send 0x8f, the command to read the WHOAMI register spi.write(0x8F);
Send a dummy byte to receive the contents of the WHOAMI register int whoami = spi.write(0x00); printf("WHOAMI register = 0x%X\n", whoami);
Deselect the device cs = 1; wait(0.1); } }<</quote>>
