8 years, 5 months ago.
define int value from uart data
I would like to create a program who read serial data and assign data in a int value like this
UART DATA (example) : 12 34 data1 <-| | | |-> data2
data1 = 12 and data2 = 34
Actually i can read uart data and store it in value[100] in ASCII, i try to convert it into int value by converting the ASCII value to integer
Can you help me ?
Fred
My software:
char value[100]; Value 0-1 => data1 || Value 2-3 => data2 int index=0; char ch;
var user int data1 = 0; int data2 = 0;
pc. printf("--Startup !--\r\n"); while(1) {
do { if (device.readable()) if there is an character to read from the device { ch = device.getc(); read it if (index<100) just to avoid buffer overflow value[index++]=ch; put it into the value array and increment the index } } while (ch!=' '); loop until the '\n' character
value[index]='\x0'; add un 0 to end the c string
Convert Ascii to int => -48
value[0] = value[0] - 48; value[1] = value[1] - 48; value[2] = value[2] - 48; value[3] = value[3] - 48;
pc.printf("data10 = %d%d, data20 = %d%d ", value[1], value[0], value[3], value[2]);
data1 = value[1]*10 + value[0]; data2 = value[3]*10 + value[4];
pc.printf("data1 = %d , data2 = %d \r\n", data1, data2);
index = 0; data1 = 0; data2 = 0; }}
