8 years, 6 months ago.
nRF52840 being seen as LPC2368
When using mBed CLI my nRF52840 shows up as a LPC2368
Below is the output of my CLI:
AD03&MI_01', 'VID_2341&PID_0001', 'VID_413C&PID_3016', 'VID_8087&PID_07DC', 'VID_8087&PID_8000'] DEBUG:mbedls.lstools_win7:_com_port looking up usb id in all usb devices DEBUG:mbedls.lstools_win7:Found usb id 6&380d98e4&1&0000 in VID_1366&PID_1015&MI_00 with subkeys ['Device Parameters', 'Properties'] DEBUG:mbedls.lstools_win7:_com_port Detecting port with Device Parameter DEBUG:mbedls.lstools_win7:_com_port port u'COM8' regtype 1 DEBUG:mbedls.lstools_base:Candidates for display [{'mount_point': u'E:', 'serial_port': u'COM8', 'target_id_usb_id': u'000683429595'}] WARNING:root:Could not read htm on from usb id 000683429595. Falling back to usb id [mbed] Detected "LPC2368" connected to "E:" and using com port "COM8"
It does read the board on the right COM port and the USB ID is correspondent with the serial number on the chip.
Can someone tell me if they had the same problems, or when the nRF52840 will be available with the online compiler? I read in another post that the online compiler should have been added end of June.
Thanks in advance.
Mark
