8 years, 6 months ago.
The Tx power is not correspond to the Uart command
Hi supporter
The result is as below.
Use in ANT_HF port.
By the way , I have tried the sx127x_simple_TX_shield.
It can nearly close to the Tx power I set.
Assigned to 8 years, 6 months ago.
Could it be that 20 dBm boost is not allowed on your frequency plan?
posted by Jan Jongboom 03 Oct 2017Assume it really can not reach 20 dBm, at least it should nearly fit the result in the third picture. 14dBm is the basic max power all end device acquire.
posted by william wu 03 Oct 2017
