8 years, 5 months ago.
MQTT
Would it be possible to use mqqt on this board?
STM32L4 Discovery kit IoT node, low-power wireless, BLE, NFC, SubGHz, Wi-Fi
Yes, over WiFi. Check the HelloMQTT application. Because the L475VG WiFi driver does not implement NetworkInterface you'll need to reimplement MQTTNetwork.h (in HelloMQTT) to work with that driver, but it's only a few functions.
Thanks for your answer. I am not an expert and I do not know how to adapt it. So I asked if there was anything prepared to work on MQTT with this board.
posted by Javier Dominguez Blanco 27 Sep 2017
How I would approach it:
  1. Use the WiFi example, and verify that it works
  2. Change the HelloMQTT app to connect to WiFi on the board
  3. Look at the functions in MQTTNetwork.h, there's only a few, and map them to the WiFi driver for the L475VG
Should be pretty straight forward.
Then MQTT should work. Unfortunately I don't have that board, so I can't patch it up.
posted by Jan Jongboom 27 Sep 2017
