8 years, 4 months ago.
How to use the "write" function in Serial library
I just need to find some examples to use de "write" or "read" functions in serial library, the objetive is to transmit data from RF modules, thats why i need to use the serial communication with the extern pins. Thanks for help.
To write to the serial port, use putc or printf:
Serial other_device(D1, D0);
other_device.putc(0x12); // sends a character
To read you have multiple options. One is to wait until there is data on the link and then receive this data, you can do this in a separate thread to not block your other code:
while (other_device.readable()) {
    char c = other_device.getc();
Or, you can read by attaching an interrupt on the serial bus, which will fire whenever there is data through the attach function.
Thanks for the information.
posted by Adalberto Corona 27 Sep 2017
