8 years, 6 months ago.
Read and Generate PPM
Hi, I have a problem with my project, where I read a PPM signal from receiver FS-iA6B and then generate new signal. I want to update the input signal according to ultrasonic sensor and output it to quadcopter fly controller. Hoverwer, It seems that when I have the InpurruptIn in a class, then It doesnt work. I tried it have the "fall" method in main and it worked well. But I want to have it nice :)
The classes are here: https://os.mbed.com/users/edy05/code/PPM2/ The PPMOut works well (not my job), but the PPMIn which I created doesn't work (in class).
Maybe are the interrupts fighting between each other, I don't know. Usually, I have to press reset button on my LPC1768 a few times to at least print values from PPMOut, sometimes it print also the PPM In values, sometimes do nothing. Please help.
This is my main.cpp
#include "PPMOut.h"
#include "PPMIn.h"
//#include "PPMIn.h"
//#include "ultrasonic.h"
//#include "MyPID.h"
#define AUX1 4
#define PIEZZO_START 0.1
#define PIEZZO_STOP 0.0
#define PPMOUT_CHANNELS 6
#define PPMIN_CHANNELS 8
PpmOut ppmOut(p26, PPMOUT_CHANNELS);
PpmIn ppmIn(p21);
uint16_t ppmOutChannelsValue[PPMOUT_CHANNELS];
uint16_t ppmInChannelsValue[PPMIN_CHANNELS];
//FUNCTIONS
void print_ppmOut(void);
void print_ppmIn(void);
int main(){
while(1){
print_ppmIn();
print_ppmOut();
if(ppmIn.rise_captured()){
pc.printf("Rise captured \n\r");
void print_ppmOut(){
ppmOut.getAllChannels(ppmOutChannelsValue);
for(uint8_t channel= 0; channel < PPMOUT_CHANNELS; channel++){
pc.printf("PPM Out Channel %d: %d \n\r", channel, ppmOutChannelsValue[channel]);
void print_ppmIn(){
ppmIn.getAllChannels(ppmInChannelsValue);
for(uint8_t channel= 0; channel < PPMIN_CHANNELS; channel++){
pc.printf("PPM In Channel %d: %d \n\r", channel, ppmInChannelsValue[channel]);
pc.printf("\n\r");
8 years, 5 months ago.
How often do your interrupts fire? It would be interesting to see if you can get rid of the problem by busy-looping and just reading the state of a pin, instead of relying on interrupts. You can run this code in a high priority thread.
Best way to find out what is really happening is to attach a debugger and look at what happens when the application crashes.
I tried to use Keli and debug the program, but even I updated firmware to version which support CMSIS-DAP I couldn't make it work - CMSIS-DAP did not shown in manager devices on my windows pc.
I figured it out this way - I have only 1 class which read PPM signal using interrupt and generate 4x PwmOut. Its much more reliable and accurate, than reading and generating PPM signal and doing it in 2 classes.
I also tried generate PPM signal in class with Thread using RtosTimer, but than I found that RtosTimer is only for task with rate 1ms and more. I needed to dynamically attach some function which changes state of pin in rate of us. But its true, that I could do it without without the function and Timeout interrupt and just do it all in one thread. Thanks for help.
posted by 27 Sep 2017
