8 years, 4 months ago.
Find time between two bytes received by UART
Hello, I am new to arm MBED. I want to measure time between two bytes. Bytes are continuously coming from a sensor. i thought to do it with UART byte receive interrupt and timer. when one byte is received and interrupt occurs, the timer starts and count until the next interrupt occurs. I tried a lot but didn't found a way to code it. it would be great if you could suggest me some code. Thanks.
Kind Regards, Saba
Use a Timer object. You can use it in an interrupt.
Thanks for replying Jan. I did it already now i am able to find this time. Can you please tell me how to receive continuously more than one byte because with pc.getc() command i can receive only one byte at a time.
posted by 27 Sep 2017Yes, you'll get the data byte by byte. You can implement a buffer yourself. E.g. something like:
char buffer[1024] = { 0 };
uint16_t buffer_ix = 0;
void uart_rx() {
buffer[buffer_ix++] = serial.getc();
serial.attach(callback(&uart_rx), /* other parameters */);
while (1) {
// check the value of buffer to see if you need to do something
Of course you need to make sure that you don't overflow the buffer.
posted by 27 Sep 2017I want to ask that for this line "serial.attach(callback(&uart_rx), /* other parameters */);" why you used callback outside (&uart_rx) because i tried with my code and i observed that the functionality in same when i use callback(&uart_rx) and when i don't use.
posted by 28 Sep 2017
