8 years, 5 months ago.
Actual clock speed is only 120MHz instead of 180MHz?
When I print the following line, I see that the system clock is only 120MHz instead of 180MHz. Is there some setting I need to change to increase the clock speed?
Code used to print SystemCoreClock
printf("SystemCoreClock = %d MHz\r\n", SystemCoreClock/1000000);
The FRDM-K66F is a low cost development platform for Kinetis® K66, K65, and K26 MCUs.
120MHz is the setting in Normal Run mode. 180MHz is available in HSRUN mode.
posted by Mahesh Mahadevan 15 Sep 2017
Hi Michael,
The answers on this question may help: https://os.mbed.com/questions/78259/System-clock/
I tried out your printf statement on my own K66F, and I am also showing 120 MHz. However, if I add the code below to my main function (before the printf statement), I now see the SystemCoreClock as 160 MHz.
SystemCoreClockUpdate();
The code above is found in the following file: /mbed-os/targets/TARGET_Freescale/TARGET_MCUXpresso_MCUS/TARGET_K66F/device/system_MK66F18.c
Let me know if you have any questions!
- Jenny, team Mbed
