8 years, 6 months ago.
Interrupts help
Hi guys,
can somebody please help me work out with these NVIC "settings" for external interrupts in mbed online compiler for NUCLEO-F767ZI? So I'd like to have 50 input interrupts. I thought that I can configure them simple by using mbed function
InterruptIn in[]={...pin names...}
and it works UNTIL I use more than 5 Interrupt pins. When I use 6, then 1 won't work, when I use 7, then 2 won't work, and so on... A think thad thad might be MBED online compilers bug. I think that the only way to configure 50 interrupts on input pins is by using NVIC or is there any other way? I know that STM32F7 doesn't have 50 external interrupt handlers - the pins are grouped together by same pin numbers, but that doesn't even bother me. I just need to have at least one interrupt handler for all 50 pins.
Best regards, Ales Zupanc
You can not use EXTI on all pins at the same time. See this question: https://developer.mbed.org/questions/78709/What-are-mbed-files-that-contain-pin-ext
And check STM32F7xx datasheet on page 26: http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/c5/37/9c/1d/a6/09/4e/1a/DM00273119/files/DM00273119.pdf/jcr:content/translations/en.DM00273119.pdf
Hm... So How can I configure all those pins as interrupt pins? PA_0, PC_15, PA_1, PC_14, PA_4, PH_1, PB_0, PC_1, PC_2, PC_0, PC_3, PD_3, PD_4, PG_2, PD_5, PG_3, PD_6, PE_2, PD_7, PE_4, PE_3, PE_5, PF_2, PF_1, PF_8, PF_0, PF_9, PD_1, PD_0, PG_1, PG_0, PE_1, PG_9, PG_15, PG_12, PG_10, PG_13, PD_9, PG_11
posted by Ales Zupanc 04 Sep 2017
You can't. Have you read my answer on the other question? Have you read the MCU's reference manual? There are 16 + 8 EXTI lines in an F7. GPIOs are grouped to EXTI channels, so you can not set same IO of multiple ports. (Example: PA_0 and PB_0 could not be interrupt in at the same time.) See figure 30 (292p) in the reference manual here: http://www.st.com/content/ccc/resource/technical/document/reference_manual/c5/cf/ef/52/c0/f1/4b/fa/DM00124865.pdf/files/DM00124865.pdf/jcr:content/translations/en.DM00124865.pdf
posted by Mark Peter Vargha 05 Sep 2017
