8 years, 6 months ago.
LowPowerTimeout
What does LowPowerTimeout stand for ? In the source code, it is a sub-class of LowPowerTicker, which is sub-class of Ticker. Then why mbed have two similiar classes ?
And there are no demo code how to use that. It seems we should add a callback for LowPowerTimeout ?
A Timeout calls some once function after a specified time interval, while a Ticker will call a function at a recurring interval.
You can view their class references here - https://docs.mbed.com/docs/mbed-os-api/en/mbed-os-5.5/api/classmbed_1_1LowPowerTimeout.html
You can use the LowPowerTicker's attach function to specify the callback, the following code example will turn on an LED after 2 seconds:
DigitalOut led1(LED1);
LowPowerTimeout timeout;
void set_led() {
led1 = 0;
led1 = 1; // Turn off LED
// Call set_led after 2 seconds
timeout.attach(&set_led, 2);
while(1);
