8 years, 7 months ago.
High accuracy measurement on NUCLEO L432KC
Hi there, I've created following code to measure the time between two pulses:
my code
Timer t; // timer to measure time between two sensor signals
Serial device(USBTX, USBRX); // for debug output on terminal
InterruptIn sensor(PA_9); // for sensor signal
int32_t delta_us = 0;
void signalOccurred() {
delta_us = t.read_us(); // global delta_us holds time difference between the last two signals now
t.reset(); // reset the timer
void sendMessage() {
device.printf("Delta = %d\r\n", delta_us); //Debug out
//send value via CAN here...
Timer sendViaCAN;
device.baud(115200);
device.printf("========== Device started up ==========\r\n");
t.start(); //global
sendViaCAN.start();
sensor.rise(&signalOccurred); // attach the address of the signalOccurred function to the rising edge
// spin in a main loop and if signal occurs interrupt it!
if (sendViaCAN.read_ms() >= 20) {
sendViaCAN.reset();
sendMessage();
I've tested it with an Arduino board which has an hardware PWM. The problem with this code is, that it is giving me different results: the values changes several µs. This is not enough accuracy for me and I think the problem lies on the software side. - Is it possible to get a better accuracy with the NUCLEO L432KC?
Hello Peter,
I have tested the code below on NUCLEO-F103RB (using an LPC1768 mbed board as PWM signal generator) and it worked with 1us accuracy (in range from 10us to 4s).
enum State
IDLE,
READY,
MEASURING,
FINISHED,
TIMEOUT
const float MEASUREMENT_TIMEOUT = 5.0f; // measurement timeout in seconds
Serial pc(USBTX, USBRX);
InterruptIn input(PA_9);
Timeout timeout;
volatile State state;
volatile uint32_t now;
volatile uint32_t begin;
volatile uint32_t period;
* @brief ISR handling 'measurement timeout'
* @note Called when input line is idle longer than expected.
* Signals 'end of measurement' by setting state to TIMEOUT.
* @param None
* @retval None
void measurementTimeout(void) {
input.disable_irq();
timeout.detach();
state = TIMEOUT;
* @brief Measures pulse period (time elapsed between two rising edges)
* @note Waits until a rising edge is detected at input or timeout occured.
* @param None
* @retval None
void measurePeriod(void) {
bool finished;
state = READY;
timeout.attach(callback(measurementTimeout), MEASUREMENT_TIMEOUT);
input.enable_irq();
do {
finished = ((state == FINISHED) || (state == TIMEOUT));
} while (!finished);
* @brief ISR handling signal rise at input
* @note Called on signal rise at input
* @param
* @retval
void onInputRise(void) {
now = us_ticker_read();
switch (state) {
case READY:
state = MEASURING;
begin = now;
break;
case MEASURING:
timeout.detach();
state = FINISHED;
period = now - begin;
break;
default:
break;
* @brief
* @note
* @param
* @retval
int main(void) {
state = IDLE;
input.mode(PullDown);
input.rise(callback(onInputRise));
while (1) {
switch (state) {
case IDLE:
measurePeriod();
break;
case FINISHED:
state = IDLE;
pc.printf("Pulse period = %dus\r\n", period);
wait(1); // prevents PC's serial terminal from overloading when period is very short
break;
case TIMEOUT:
state = IDLE;
pc.printf("Measurement timeout. No signal detected at input.\r\n");
break;
default:
break;
Zoltan
