8 years, 7 months ago.
InterruptIn problem
Hi guys, I have a simple program with some interrupts and I don't know what am I missing here. I want to define InterruptIn pins in the buffer (for DigitalIn and DigitalOut this is possible is it possible also for InterruptIn?), like I did in the program here (it is not working):
Serial debug(USBTX, USBRX,230400);
InterruptIn din[] = {PA_0, PC_15, PA_1, PC_14, PA_4, PH_1};
void test(){
    debug.printf("test");
    din[0].mode(PullUp);
    din[0].fall(&test);
    while(1){}
...but if I do it like in the next program all works perfectly:
InterruptIn din0 = (PA_0);
void test(){
    din0.mode(PullUp);
    din0.fall(&test);
    while(1){}
Thanks for all the help.
Ales Zupanc
Hello Ales,
Try to call the constructor for each element when creating the din array as below:
InterruptIn din[] = { InterruptIn(PA_0), InterruptIn(PC_15), InterruptIn(PA_1), InterruptIn(PC_14), InterruptIn(PA_4), InterruptIn(PH_1) };
NOTE:
  • When building offline with GCC toolchain you have to do the same also in your second example. Otherwise the code won't compile.
  • debug has already been declared as static inline void debug(const char *format, ...) in mbed_debug.h so you should choose a different name for the Serial object.
    Zoltan
