8 years, 6 months ago.
Connectig NUCLEO-L432KC to SHT25 using I2C
Hi im new using mbed, Recentrly I bought a L432KC and start rightaway experimenting with it, but now Im having trouble trying to get conected to a SHT25, I'm already using the pullup resistors, I'm using the Nucleo_i2c_master by arostm, and adaped it to my needs, I'm not sure if something is missing but from what I read from de Datasheet, SHT25 doesnt have a start register, so I'm using only the address (0x40) and the temp register(0xE3), here is the code:
#define LM75_REG_TEMP (0xE3) // Temperature Register
//#define LM75_REG_CONF (0x01) // Configuration Register
#define LM75_ADDR (0x40) // LM75 address
I2C i2c(PB_7, PB_6);
DigitalOut myled(LED2);
Serial pc(USBTX,USBRX);
volatile char TempCelsiusDisplay[] = "+abc.d C";
//i2c.start();
i2c.frequency(125000);
char data_write[] = {0};
char data_read[2];
/* Configure the Temperature sensor device STLM75:
- Thermostat mode Interrupt
- Fault tolerance: 0
data_write[0] = LM75_REG_TEMP;
int status = i2c.write(LM75_ADDR, data_write, 1, 0);
//pc.printf("status: %d\n",status);
if (status != 0) { // Error
while (1) {
myled = !myled;
wait(1);
pc.printf("ERROR!\n\n");
while (1) {
// Read temperature register
i2c.write(LM75_ADDR, data_write, 1, 1); // no stop
i2c.read(LM75_ADDR, data_read, 2, 0);
// Calculate temperature value in Celcius.
int tempval = (int)((int)data_read[0] << 8) | data_read[1];
tempval >>= 7;
if (tempval <= 256) {
TempCelsiusDisplay[0] = '+';
} else {
TempCelsiusDisplay[0] = '-';
tempval = 512 - tempval;
// Decimal part (0.5°C precision)
if (tempval & 0x01) {
TempCelsiusDisplay[5] = 0x05 + 0x30;
} else {
TempCelsiusDisplay[5] = 0x00 + 0x30;
// Integer part
tempval >>= 1;
TempCelsiusDisplay[1] = (tempval / 100) + 0x30;
TempCelsiusDisplay[2] = ((tempval % 100) / 10) + 0x30;
TempCelsiusDisplay[3] = ((tempval % 100) % 10) + 0x30;
// Display result
pc.printf("temp = %s\n", TempCelsiusDisplay);
myled = !myled;
i2c.stop();
wait(1.0);
I know Im not using the proper formula for obtaining the temperature, but doesnt matter because it never gets passed the if status condition, it always returns 1, I havent guessed what's wrong.
Thanks for the help!
Hello Agustín,
Because SHT25 is almost identical to SHT21, to get started I'd suggest to import the sht_21_test program (e.g. by clicking on the [Import program] button). Then modify line #5 as follows:
SHT2x sht21(PB_7, PB_6);
If that program does not work because of unsupported I2C byte write and read operations then try the following:
- Create a new project and edit
main.cppas follows:
#include "SHT2X.h"
Serial pc(USBTX, USBRX);
SHT2X sht25(PB_7, PB_6); // I2C SDA pin name, I2C SCL pin name
float temperature;
float humidity;
sht25.readData(&temperature, &humidity);
pc.printf("temperature = %5.2f%cC\r\n", temperature, 176);
pc.printf("humidity = %5.2f%%RH\r\n\r\n", humidity);
wait(1);
- Save
main.cppand import the SHT2X library into your project (by clicking on the [Import into Compiler] button located in the top-right corner of the library's home page). - In the SHT2X folder of your project open the
SHT2X.hfile and modify the declaration ofSHT2Xclass as follows:
class SHT2X {
public:
//SHT2X(I2C& i2c);
SHT2X(PinName sda, PinName scl); // new line
int readData(float *tempC, float *relHumidty);
int measureTemperature(float *tempC);
int measureHumidty(float *relHumidty);
int setPrecision(char precision);
bool softRest();
protected:
I2C m_i2c;
//Serial pc;
private:
SHT2X.cppfile and modify the definition of theSHT2Xconstructor as follows:
//SHT2X::SHT2X(I2C& i2c) : m_i2c(i2c), pc(p5,p4) {
SHT2X::SHT2X(PinName sda, PinName scl) : m_i2c(sda, scl) {}
Then compile.
Zoltan
