8 years, 6 months ago.
ADXL355
Hi, I am trying to use FRDM-k64f to read the new accelerometer ADXL355. I am referring to the example ADXL345. First, I try to test the SPI communication using below code. Why I always get 0 ?
SPI acc(PTD2,PTD3,PTD1);
DigitalOut cs(PTD0);
Serial pc(USBTX, USBRX);
char buffer[9];
signed short data[3];
float x, y, z;
int deviceID;
char test;
 cs=1;
 acc.format(8,0);
 acc.frequency(2000000);
   while (1) {
     wait(1);
     cs=0;
   acc.write(0x80|0x01);
   deviceID= acc.write(0x00);
  pc.printf("partid= %d\r\n",deviceID);
  cs=1;
Thank you so much.
/media/uploads/cornetlin/wire.png /media/uploads/cornetlin/adxl354-adxl355_breakout_ug-xxx_july22.pdf /media/uploads/cornetlin/adxl354_355.pdf
Hello Tzu-Hsuan,
acc.format(8,0); acc.frequency(10000000);
write ... acc.write( (address << 1) | 0x00); acc.write(data); ....
read ... acc.write( (address << 1) | 0x01); acc.write(0x00); ....
Hello Tzu-Hsuan,
Referring to the ADXL345 library I think instead of calling
acc.format(8,0);
    acc.write(0x80 | 0x01);
you should try to call
acc.format(8,3);
    acc.write(0x80 | (0x00 & 0x3F));
or simply
acc.format(8,3);
    acc.write(0x80);
Zoltan
