8 years, 7 months ago.
[nRF52832] Unable to configure InterruptIn + PullDown on P0_1
Hello !
I am currently working on a custom board on which I don't need 32.768kHz. I want to use P0_1 as an interruption pin connected to a pushbutton. The button is connected to VCC so when it's pressed it imposes a high logical level on the GPIO. I configured configured the GPIO to enable the internal pull-down so the low logical level is forced when pushbutton is not pressed.
InterruptIn code example
bool pressed = false;
void pushbutton1_handler( void )
   pressed = true;
InterruptIn bp1( P0_1 );
int main( void )
   bp1.rise( &pushbutton1_handler );
   bp1.mode( PullDown );
      if( pressed == true ) {
         LOG("pressed\r\n");
         pressed = false;
I run this code and measure the voltage on P0_1, which is supposed to be grounded, but I measure 3.3V
Is there a known issue related to this situation ?
Thanks
