8 years, 3 months ago.
Temperature Sensor to only sense when there is a value
Hello. I am working with LM35 Temperature Sensor. I only want the temperature to print the temperature when it senses a new value (a value different from the one sensed and stored previously). This is my code, but i can't get it.
AnalogIn analog_value(PA_0);
    float temp;
    float prevalue=0;
    float currvalue;
              currvalue = analog_value.read();
              if(prevalue==currvalue){
              wait(0.1);  }
              else{
              temp = ((currvalue*5000)/10);
              pc.printf("temprature = %.0f ^C\r\n", temp);
              prevalue=currvalue;
Hello Fawaz,
Since the measured temperature is always a bit floating I would suggest to neglect small changes for example as follows:
int main(void) {
    const float DELTA = 1.0;    // in degree C
    const float CONV = 3300 / 10;
    float       prevvalue = 0;
    float       currvalue;
    while (1) {
        currvalue = analog_value.read() * CONV;
        if (((prevvalue - DELTA) < currvalue) && (currvalue < (prevvalue + DELTA))) {
            wait(0.1);
        else {
            prevvalue = currvalue;
            pc.printf("temprature = %5.1f%cC\r\n", currvalue, 176);
Regarding the correctness and conversion of values measured with LM35 temperature sensor also have a look at:
https://developer.mbed.org/questions/6317/AnalogIn-problem-pics-included-strange-v/
TIP FOR EDITING: You can copy and paste a code into your question as text and enclose it within <<code>> and <</code>> tags as below (each tag on separate line). Then it's going to be displayed as code in a frame.
<<code>>
DigitalOut led1(LED1);
    while (1) {
        led1 = !led1;
        wait(0.5);
<</code>>
Thank you. But this did not work, instead it became worse than before, it will rapidly print he values.
posted by Fawaz Sammani 22 Aug 2017
Try to increase DELTA step by step until it doesn't print values rapidly.
posted by Zoltan Hudak 22 Aug 2017
