8 years, 4 months ago.
NucleoL476 + IDW01M1 Wifi send data to Ubidots
I'm trying to post data to Ubidots Cloud service (1 variable)
I'm using NucleoL476 and X-Nucleo-IDW01M1 wifi shield and nothing is udpated to Ubidots. When I try same command API with hurl.it, It working. Socket.recv() return -3001 ?
Here my terminal results:
######## IDW01M1 NetworkSocketAPI TCP Client Ubidots Example
Connecting to AP
Now connected
IP address is: 192.168.0.17
MAC address is: 00:80:E1:B7:C5:D8
things.ubidots.com resolved to: 50.23.124.68
Socket connected
{"value": 2114}
POST /api/v1.6/variables/5997efbdc03f971ca757920a/values HTTP/1.1
Content-Type: application/json
Content-Length: 15
X-Auth-Token: A1E-B0I6Hzcqxxtl0ecHPOrApvvkoABQE8
Host: things.ubidots.com
{"value": 2114}
Send data to Ubidots
Received -3001 ##########
Code is attached /media/uploads/rrom/main.cpp
Thanks for help.
8 years, 3 months ago.
I've just tested your request with mbed-http and that works fine for me (although I get a 404, I guess the thing has been removed):
HttpRequest* get_req = new HttpRequest(network, HTTP_POST, "http://things.ubidots.com/api/v1.6/variables/5997efbdc03f971ca757920a/values");
get_req->set_header("Content-Type", "application/json");
get_req->set_header("X-Auth-Token", "A1E-B0I6Hzcqxxtl0ecHPOrApvvkoABQE8");
const char* buffer = "{\"value\": 98}";
HttpResponse* get_res = get_req->send(buffer, strlen(buffer));
if (!get_res) {
    printf("HttpRequest failed (error code %d)\n", get_req->get_error());
    return 1;
printf("\n----- HTTP GET response -----\n");
dump_response(get_res);
delete get_req;
Could you try that? HTTP is notoriously harder than it looks at first glance even though your HTTP request seems valid.
Hello Jan,
First of all a big thank you for your answer.
Have you tested this solution with the same hardware as me? Before testing your code, do I need to keep the Socket library?
Could you share the whole of your main.cpp?
Thank you.
posted by rom r 30 Aug 2017
I tested with ODIN-W2 and K64F boards, unfortunately I don't have IDW01M1 shield on hand, but -3001 is often a sign that the server is still waiting for the request, and then the socket times out, so it's probably a malformed HTTP request. I've put my main.cpp here, hope it helps.
posted by Jan Jongboom 30 Aug 2017
