8 years, 7 months ago.
I2C General Call on STM32F303K8
I use a STM Nucleo with the F303K8.
Now it should do a I2C connection as a slave. For this I used the I2CSlave Simple I2C responder example.
#include <mbed.h>
I2CSlave slave(p9, p10);
char buf[10];
char msg[] = "Slave!";
slave.address(0xA0);
while (1) {
int i = slave.receive();
switch (i) {
case I2CSlave::ReadAddressed:
slave.write(msg, strlen(msg) + 1); // Includes null char
break;
case I2CSlave::WriteGeneral:
slave.read(buf, 10);
printf("Read G: %s\n", buf);
break;
case I2CSlave::WriteAddressed:
printf("Read A: %s\n", buf);
break;
for(int i = 0; i < 10; i++) buf[i] = 0; // Clear buffer
My Master send data to my slave adresse - everything is working.
When the Master do a data transfer to general call adress (0x00) then nothing happens.
Now i take a look to the Reference manual. There I can see: "The General Call address is enabled by setting the GCEN bit in the I2C_CR1 register."
So I set this with;
I2C1->CR1 |= I2C_CR1_GCEN;
Now I get an response to the General call transfer. But the same as an direct adresses transfer. I could not determine adressed and general call.
