8 years, 7 months ago.
how to print a statement for mbed on Eclips window
Hello Can anyone please tell me how can i use Serial pc(SERIAL_TX, SERIAL_RX); on Eclips using mbed for library offline IDE compiler. Serial gives an error on Eclips and i can't use print statement. If someone knows how can i remove this error then please answer. Im using Nucleo F429 board on Ubuntu. Thank you
Hello Ali,
One simple solution is to use the default serial port which is automatically created by the mbed library. So you do not need to create a serial object (like Serial pc(USBTX, USBRX);). Instead you just call the global printf function as below. In this case also the binary code becomes smaller. The default settings are 9600 bits/s, one start bit, eight data bits, no parity bit, one stop bit. However, make sure that the mbed serial driver for the NUCLEO-F429 is installed on your PC and the mbed board is connected to the PC over a USB cable.
//Serial pc(USBTX, USBRX);
void main() {
//pc.printf("Hello, World!\r\n);
printf("Hello, World!\r\n");
If the error says something like:
- error: 'MBED_CONF_PLATFORM_DEFAULT_SERIAL_BAUD_RATE' was not declared in this scope
- error: call to 'mbed::Serial::Serial(PinName, PinName, const char*, int)' uses the default argument for parameter 4, which is not yet defined
And there is an mbed_config.h file available in your project exported from the online compiler, then one ways how to fix it is adding #include "mbed_config.h" to the device.h header file associated with your target mbed board as below:
device.h
#ifndef MBED_DEVICE_H #define MBED_DEVICE_H //======================================= #define DEVICE_ID_LENGTH 24 #include "mbed_config.h" #include "objects.h"
After such modification you should be able to create instances of the Serial class in your program.
NOTE: For the NUCLEO-F429ZI board you should be able to find the associated device.h file in the mbed/targets/TARGET_STM/TARGET_STM32F4 folder.
