8 years, 7 months ago.
How to solve "dropped 'gdb' connection" error in Eclips
Hello everyone. I'm facing a problem wtih Nucleof429zi board with Eclips and ubuntu in offline IDE. i performed all the configuration and everything was working fine. Then later i'm facing a problem as shown below
Open On-Chip Debugger 0.9.0 (2017-08-13-11:53) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'. Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 2000 kHz adapter_nsrst_delay: 100 none separate Started by GNU ARM Eclipse Info : Unable to match requested speed 2000 kHz, using 1800 kHz Info : Unable to match requested speed 2000 kHz, using 1800 kHz Info : clock speed 1800 kHz Info : STLINK v2 JTAG v28 API v2 SWIM v18 VID 0x0483 PID 0x374B Info : using stlink api v2 Info : Target voltage: 3.222991 Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints Info : accepting 'gdb' connection on tcp/3333 Info : device id = 0x20016419 Info : flash size = 2048kbytes target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x08001210 msp: 0x20030000 semihosting is enabled target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x08001210 msp: 0x20030000, semihosting Info : Padding image section 0 with 596 bytes target state: halted target halted due to breakpoint, current mode: Thread xPSR: 0x61000000 pc: 0x20000042 msp: 0x20030000, semihosting target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x08001210 msp: 0x20030000, semihosting Error: gdb requested a non-existing register Info : dropped 'gdb' connection
How can i get rid off this problem. I read from many blog that i have to remove some tdesc line from .gdbinit file but i'm unable to fine it. Please share your ideas. Thank you
Hi Ali,
Glad you were able to solve your issue! I'm closing this question.
- Jenny, team mbed
i found the answer and it's working for Ubuntu and eclips oxygen with openocd 0.9 you just need to add this line in your target device in my case it's stm32f4x.cfg
$_TARGETNAME configure -event gdb-detach { shutdown }
posted by Ali Imran Siddiqui 13 Aug 2017Hey man! I found your answer, and i am also having an STM32 that is not working as it should. Could you please detail your answer, for the lesser insightful? :) Thanks in advance!
posted by dark blackmail 23 Sep 2017
