8 years, 7 months ago.
Read Frequency from external Input
Hello everyone.
I'm currently working on a motor controller from my upper apprentice and my task is to measure a precise rpm from the motor. Now, I read that there's a capture feature from Timer2 or something and I want to use this capture thing to get precise timings to then calculate the frequency and rpm.
The problem is: I don't know how to use this capture feature? I'm not a beginner in programming but I'm a beginner in reading datasheets and convert the information to code from the DS.
I would be thankful, if you could help me with this problem.
Hello Joel,
This frequency counter isn't a sophisticated program but maybe can help you get started.
Or see Kenji's Simple Frequency Counter if you need higher accuracy.
