8 years, 7 months ago.
Blinky programs not working on 3 separate nRF52832 boards
Hello MBed,
The online compiler seems to have corrupted the support for the nRF52832. I have 2x nRF52-dks (v1.0.0 and v1.1.0), as well as a custom board with the kl26z as an interface chip (with a correct/working bootloader). Blinky does not work on either of the nrf52-dks, and RawSerial works on none of them.
I can only use an older mbed-os 5.2 offline repository (which would be fine except I can't find a working SD card library... SDFileSystem hangs the nRF52 after the next interrupt, and SDBlockDevice is not supported on mbed-os 5.2).
Could anyone with an nrf52-dk confirm if their board works with the online compiler and what version the board is?
What are you testing with - which revision of mbed OS/mbed lib?
posted by Martin Kojtal 06 Aug 2017After right-clicking the 'mbed-os' component and hitting 'Revisions', I see that the latest update is to 5.5.4
posted by Lance Norman 06 Aug 2017so that's what I am using (I assume mbed-os updates to the latest version if I right click it and select 'Update')
