8 years, 8 months ago.
How to measure battery percentage
Hi All,
I am pretty new to mbed and also new to electronics in general. I am trying to develop a small application that checks the battery percentage and based on that it will make an HTTP connection to our server. I am using an MTQ-H5-B01 dragonfly on a UDK2 board, and a 3.7v Lithium Polymer battery.
So my questions are:
1) How to get the voltage and measure the battery percentage?
2) If measured, how to know if voltage measured is coming from battery or direct plugin?
I have checked the below links but they are not providing required results:
https://docs.mbed.com/docs/mbed-os-api-reference/en/5.2/APIs/io/AnalogIn/
https://developer.mbed.org/users/tylerjw/notebook/battery-voltage-monitor/
Regards, Dawit
To mesure the battery-voltage you need some kind of reference-voltage, e.g. a linear-regulator or the supply of the mcu, then you can compare the two voltages (via analog-in and a voltage-divider). The plug-in-detection could be managed with a digital-in-pin connected to the supply-line of the charging-circuit (pay attention on on the maximum input-voltage and use a voltage-divider is needed). Some battery-charger-ICs provide informations about the battery, I don't know your board, maybe you can use something like that.
posted by Theo Bestenlehner 06 Aug 2017
Dawit,
It's almost impossible to accurately predict battery percentage from voltage alone.
This stack exchange article is a good introduction:
https://electronics.stackexchange.com/questions/18818/reading-a-li-po-batterys-remaining-charge
Cheers, Nick
