8 years, 8 months ago.
mbed-os 5 maximum number of threads
This is the 3rd time I am asking the same question. My earlier two attempts in the same context, didn't receive any response. The questions never appeared under the "Question" tab. While posting the questions, I saw the status "Waiting for moderation". Hence I am not even aware if anybody is attending the question. This time I am hoping that somebody would attend or at least acknowledge. So following is the problem description.
I am testing how many maximum threads may be spawned in Cortex-M4 targets with mbed-os 5.x by default (w/o me changing any configuration). The target is Nucleo-F303RE. But I am sure the problem is not target specific.
1. Online build - This didn't allow me go beyond 6 thread (1 main + 5 threads). The thread start returned non zero when 6th thread creation was attempted. I further investigated and understood that there is a define OS_TASKCNT that decides how many maximum threads may be spawned. The mbed-os source tree revealed that the said (OS_TASKCNT) define doesn't appear any where except under Realtek target file mbed_rtx.h.
2. offline build - This did allow me to go beyond 12 (1 main + 11 threads) threads. While spawning 13th thread got run time error message "Operator new[] out of memory". The mbed-os repository version was the one that was clone under running mbed-cli. i.e "mbed new mbed-os-program". In the repository, I found that OS_TASKCNT was defined only in STM and Realtek targets.
So my questions are: 1. Is OS_TASKCNT still in use and decides maximum number of threads? 2.1. If answer to question #1 is yes, where is OS_TASKCNT defined? 2.2. Why is it defined only for certain target(s)? 2.3. What is the default value for any target? 2.4. What are other defines that are related to OS_TASKCNT, that are required to be configured for reasonable values so as to not get any run time error? I would prefer compile time error, if possible. 3.1 If answer to question #1 is no, how is (max number of threads) defined?
4. Studied the RTX5 code and there are two files that define all OS_ configuration options. But the values there (OS_THREAD_NUM in particular) is doesn't appear to be in sync with the run time results I am getting (mentioned earlier). I also studied mbed_app.json. But if the file is not present what are default values for all OS_* configuration options?
Thanks, Hemant
The only limitation is the amount of memory that you have available on the target, and how big your stack size per thread is.
With default settings a thread takes up about 4.4K of heap space. Thus, on a K64F I can create 40 threads (heap size of 183K). If I set the stack size to 2K per thread I can create 77. All built with GCC_ARM against mbed OS 5.5.
Here's a small program to test it (set the MBED_HEAP_STATS_ENABLED=1 macro beforehand):
#include "mbed_stats.h"
void wait_forever() {
wait(osWaitForever);
Serial pc(USBTX, USBRX);
pc.baud(115200);
mbed_stats_heap_t heap_stats;
size_t thread_count = 0;
while (1) {
mbed_stats_heap_get(&heap_stats);
printf("Current heap: %lu / %lu\r\n", heap_stats.current_size, heap_stats.reserved_size);
Thread* t = new Thread(osPriorityNormal, 2*1024);
t->start(&wait_forever);
printf("Thread count is now %d\n", ++thread_count);
wait_ms(1000);
Regarding OS_TASKCNT, I'm not sure. In mbed OS 5.4 and mbed OS 5.5 it's not used anymore, so I guess the limit was removed and now the only limit is available memory.
