8 years, 7 months ago.
How To use mbedTLS with ESP8266-01 in NUCLEO-F401RE?
I want to use mbedTLS library with ESP8266-01 module in NUCLEO-F401RE. but if not use 'LWIP' at STM32 board, can't compile my project( this is mbedTLS & MQTT ) please help me anyone.
7 years, 7 months ago.
Hello
I'm also have same question. The solution is temtative because its "TESTING".
I want to know, can I use SW TRNG with any crupto library ? if possible, how to configure ?
Best Regards
I'm not sure what you're trying to do, but http-example uses F401RE with ESP8266 module and also includes mbed TLS, so maybe use it a starting point.
i want to test 'alexa-iot' example. and already test and work normally with DISCO-F746NG board. but this board has Ethernet(wired) only. so i change target board(F401RE) in my project and add 'ESP8266' library. but i can't compile. i saw error message( undefined reference mbedtls_ssl_init and other ).
posted by Jeon byungchul 03 Aug 2017
Where did you find the example? I can't find the 'alexa-iot' project...
posted by Jan Jongboom 03 Aug 2017
https://developer.mbed.org/users/peyo/code/AWS-test/ this is connect with AWS IoT.
First, add the esp8266-driver library. Then, in the code, where it says EthernetInterface (and #include EthernetInterface.h) replace with:
#include "ESP8266Interface.h"
ESP8266Interface net(D8, D2, true);
And pass in SSID and password in the connect call.
But I can't compile the AWS-test program, so I can't verify if it actually works.
thanks for your help. i will try to make my repository. but i don't know how to do. I will share my current project with you.
posted by Jeon byungchul 04 Aug 2017
my project uploaded in repository(https://developer.mbed.org/users/jeonbc/code/aws-iot-example). you have to export it( GCC_ARM/NUCLEO_F401RE ) first. then, add 'CXX_FLAGS += -std=gnu++11' at makefile. you can see error message.
You'll need to set an entropy source, otherwise the ssl functions are not linked in. For TESTING you can define a NULL entropy source by declaring these macros:
MBEDTLS_TEST_NULL_ENTROPY and MBEDTLS_NO_DEFAULT_ENTROPY_SOURCES
I've tested your code with these macros enabled and then the program compiles.
Side-note: you cannot use pin D1/D0 for UART on NUCLEO-F401RE because they are used by USB. Use D8/D2 instead.
posted by Jan Jongboom 04 Aug 2017
ASM_FLAGS += -DMBEDTLS_TEST_NULL_ENTROPY & ASM_FLAGS += -DMBEDTLS_NO_DEFAULT_ENTROPY_SOURCES. added in Makefile. but compile can't. please tell me detail.
posted by Jeon byungchul 07 Aug 2017
These macros need to be set under C_FLAGS and CXX_FLAGS, not under ASM_FLAGS. If you're building with mbed CLI you can also add them under the macros section in mbed_app.json
posted by Jan Jongboom 07 Aug 2017
I succeeded after I followed your instructions. thanks your help.
