8 years, 8 months ago.
Pin operations
The most basic task on a microcontroller - which I cannot get right - toggling port pins. I am using Nucleo Board F103-RB. My knowledge of C programming is reasonable .... my knowledge of C++ is roughly zero ....
at the start of main.cpp if I do this:
#define TESTPIN PB_7 DigitalInOut mypin(PinName TESTPIN);
... I assume that I am instantiating a DigitalInOut pin OBJECT which will have various methods available. I look in the API documentation to find them and then I expect to use these methods like this:
// set pin to have open drain output mypin.mode(OpenDrain); // set pin to output mypin.output(); // set pin low mypin.write(0); wait_us(400); // set pin high mypin.write(1); wait_us(100); mypin.write(0); wait_us(100); // set pin as input mypin.input; wait_us(100);
yet this will not compile - each 'method' reports error 153 .... "Error: Expression must have class type"
What am I doing wrong?
You should declare the pin as;
DigitalInOut mypin(TESTPIN);
The ''PinName'' in front is wrong.
