8 years, 7 months ago.
how to send char but receive string on L073RZ using UART?
Troubleshooting!
Hi anyone mind helping me to take a look and help me correct it? cuz i have been trying to change my receiving of char into string but can't seem to do it. The code below is how my current working code looks like.
main.cpp
//| Hyperterminal configuration |
//| 115200 bauds, 8-bit data, no parity |
Serial pc(SERIAL_TX, SERIAL_RX); //PC to STM32 Board
//Serial transmit(PC_4,PC_5); // STM32 writing/reading with Arduino
Serial uart(PC_4,PC_5);
//DigitalOut myled(LED1);
DigitalIn BlueButton(USER_BUTTON); // This is Blue-Button and is on NUCLEO-L153RE
DigitalOut pc_activity(LED1);
DigitalOut uart_activity(LED2);
#define Pressed 0
#define NotPressed 1
pc.printf("Select one of the following...");
pc.printf("\r\n");
pc.printf("i = deice type and version number");
pc.printf("\r\n");
pc.printf("r = take a single pH reading");
pc.printf("\r\n");
uart.baud(115200); //Setting of baud rate
if(pc.readable()) { //If PC port got reading/get input of char
uart.putc(pc.getc()); //Sending char to arduino
pc.printf("Message Sent!\r\n");
pc_activity = !pc_activity; //LED indication
if(uart.readable()) { //UART excute only when receive reading
pc.printf("Message Received:");
pc.printf("\r\n");
pc.putc(uart.getc()); //Receving char from arduino
pc.printf("\r\n");
uart_activity = !uart_activity; //LED indication
Hi there,
scanf() might be what you're looking for:
char buffer[20];
if (uart.readable()) {
pc.putc(uart.scanf("%s", &buffer));
However, the above code snippet will only work if you are also receiving a "carriage return" character (\r) from your uart.
- Jenny
Troubleshooting!
Hey hi Jenny,
I tried using scanf() but is not working. i currently using "carriage return" on my arduino side but for my STM i also using "carriage return". Now trying to send byte from arduino to STM but i can receive but cannot display on the terminal. Because i am actually trying to receive bytes in array to display on terminal. The code below is what my current code looks like.
//pc_activity = !pc_activity; //LED indication
pc.printf("in while getc\n");//test
int i=0;
while(uart.getc() != 'E')
pc.printf("in \n");//test
buffer[i]=uart.getc();
wait(0.5);
i++;
pc.printf("uart is %s",buffer);
pc.printf("\r\n");
pc.printf("\r\n");
-Mel
posted by 19 Jul 2017
