8 years, 2 months ago.
SMS Program using MTSCellularInterface on Dragonfly not working
I am new to mbed environment and I am trying to test some sample codes. I cloned an example that uses the MTSCellularInterface library but it is not working.
I am using MTQ-H5 dragonfly on MTUDK2-ST board.
Below is the example:
// This example program will first delete any stored messages held in the radio. // Then it will send an SMS message before looping while reading received SMS // message. // // ** Configure the apn[] value below for MTQ-H5 or MTQ-LAT3 radios. // ** Configure txtmsg.phone_number below for SMS destination. #include "mbed.h" #include "MTSCellularInterface.h" #include "MTSLog.h" #include "example_config.h" #if ACTIVE_EXAMPLE == SMS_EXAMPLE // Dragonfly debug port. Serial debug_port(USBTX, USBRX); int main(){ //Sets the log level to INFO, higher log levels produce more log output. //Possible levels: NONE, FATAL, ERROR, WARNING, INFO, DEBUG and TRACE. //For the Dragonfly, installed on the UDK 2.0 board, messages are output on the // UDK 2.0 USB port “COMxx: STMicroelectronics STLink Virtual COM port (xx)” // at 9600bps. mts::MTSLog::setLogLevel(mts::MTSLog::INFO_LEVEL); //Sets the debug port to 115200bps. debug_port.baud(9600); // Create an MTSCellularInterface object. Serial pins for the Dragonfly board that connect // to the on board cellular radio: // RADIO_TX = pin PC_7, RADIO_RX = pin PC_6 MTSCellularInterface *radio = new MTSCellularInterface(RADIO_TX, RADIO_RX); // Print the MTSCellularInterface version logInfo("MTSCellularInterface Version %s", radio->get_library_version().c_str()); //Modify to match your apn if you are using an HSPA radio with a SIM card. const char apn[] = "rogers-core-appl1.apn"; //Phone number to send to and receive from. Must be in the form "1xxxxxxxxxx" MTSCellularRadio::Sms txtmsg; txtmsg.phone_number = "12045581111"; txtmsg.message = "Hello World! MTSCellularInterface is up and running!"; //Set radio apn for (int i = 0; i < 10; i++) { if (i >= 10) { logError("Failed to set apn\n"); } else if (radio->set_credentials(apn) == NSAPI_ERROR_OK) { logInfo("Successfully set apn\n"); break; } else { wait(1); } } //Delete any previously received SMS messages for (int i = 0; i < 10; i++) { if (i >= 10) { logError("Failed to delete SMS messages\n"); } else if (radio->delete_all_received_sms() == NSAPI_ERROR_OK) { logInfo("Deleted all SMS messages\n"); break; } else { wait(1); } } // Send SMS message to phone for (int i = 1; i < 10; i++) { if(radio->send_sms(txtmsg) == NSAPI_ERROR_OK) { logInfo("Sent SMS successfully:<%s>\n", txtmsg.message.c_str()); break; } else { logError("Failed to send SMS<%s>\n", txtmsg.message.c_str()); } } //Checking for received SMS messages while (true) { logInfo("Checking for received messages"); vector<MTSCellularRadio::Sms> recv = radio->get_received_sms(); if(recv.size() > 0) { int size = recv.size(); for (int i = 0; i < size; i++) { logInfo("Message %d: [%s] [%s] [%s]", i, recv[i].phone_number.c_str(), recv[i].timestamp.c_str(), recv[i].message.c_str()); } } if(radio->delete_only_read_sms() != NSAPI_ERROR_OK) { logError("Failed to delete received and read SMS messages"); } wait(10); } return 0; } #endif
And below is a output I get:
[INFO] Radio model: MTQ-H5 [INFO] MTSCellularInterface Version v0.1.1 [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed [ERROR] Failed to send SMS<Hello World! MTSCellularInterface is up and running!> [ERROR] CMGF failed
I tried different working SIM cards with data enabled, but I get the same output even if I don't insert any SIM card.
When I set the debug port to 115200bps, I get a weird outputwith characters I cannot understand.
Thanks all of you in advance.
