8 years, 9 months ago.
FRDM K64F - Can't build the majority mbed APIs?
Hi all,
I am currently struggling to run the example CAN API code for the FRDM K64F board? *example code from here https://docs.mbed.com/docs/mbed-os-api-reference/en/latest/APIs/interfaces/digital/CAN/
I have also tried the other examples including Ethernet to no avail etc. The build error I consistently get is that the functions and types (from the API) aren't recognised.
/media/uploads/ConnorMcShane/screen_shot_2017-07-12_at_3.41.37_pm.png
It works for other boards such as the LPC1768. It must be that the new mbed OS API's isn't fully compatible with the FRDM K64F board but I was just looking for confirmation on this.
Thanks for your time
This MCU has only one CAN interface, pins are PTA12 and PTA13. Check here: http://cache.freescale.com/files/microcontrollers/doc/data_sheet/K64P144M120SF5.pdf
But there is no CAN support for this target in mbed. Check pin names here, no CAN pins: https://github.com/ARMmbed/mbed-os/blob/mbed-os-5.5/targets/TARGET_Freescale/TARGET_MCUXpresso_MCUS/TARGET_MCU_K64F/TARGET_FRDM/PeripheralPins.c
You can use the driver from the manufacturer to implement the missing layer.
Thanks for your help Mark, sorry I am new to this stuff (university student). So you mean to find the CAN driver source (*.c and *.h) and manually include them in the mbed compiler directory and then try and build again?
Thanks
posted by Connor McShane 14 Jul 2017
Does K64F support CAN? I believe it does not. Ethernet it does, therefore it should work. Please provide what is mbed/mbed OS version that you use, what are errors you are seeing, anything that can help to reproduce.
K64F does support CAN, I think as mentioned above the mbed os doesn't support CAN for this board.
I was compiling with the latest mbed 5 (updated version). The first compile error I was getting was Identifier "CAN" is undefined "CAN can1(MBED...." which is silly since the mbed documentation explicitly describes CAN as an object type from the CAN library.
