8 years, 8 months ago.
[F429ZI+AT86RF233] Thread communication lost after deepsleep
Hello!
I've been recently fighting with some issue. I am building application on mbed os for thread communication using Nucleo_F429ZI and AT86RF233 radio. My device is configured as thread sleepy end device. The idea is to read some measurements, send them via Thread network and put microcontroller to deepsleep. RTC generates wakeup interrupts. The problem is about sending packages of data. Everything is going in proper way when i put an endless loop between interrupts. But when i'm trying to put deepsleep() after data sending - nothing happens. I'm receiving nothing in UDP terminal on my PC. Another issue is that sleep() function doesn't work at all. I've been measuring power consumption during callig sleep() but there is no difference, Here is my code:
#include "rtos.h"
#include "NanostackInterface.h"
#include "mbed-trace/mbed_trace.h"
#include "socket_example.h"
#include "common_functions.h"
#include "ip6string.h"
#include "socket_api.h"
#include "UDPSocket.h"
#include "sensors/SensorCollection.h"
#include "rtc_api_hal.h"
#include "mbed_sleep.h"
#include "mbed_events.h"
#include "rtos_idle.h"
void trace_printer(const char* str) {
printf("%s\n", str);
#define ATMEL 1
#define MCR20 2
#define NCS36510 3
#define MESH_LOWPAN 3
#define MESH_THREAD 4
#if MBED_CONF_APP_RADIO_TYPE == ATMEL
#include "NanostackRfPhyAtmel.h"
NanostackRfPhyAtmel rf_phy(ATMEL_SPI_MOSI, ATMEL_SPI_MISO, ATMEL_SPI_SCLK, ATMEL_SPI_CS,
ATMEL_SPI_RST, ATMEL_SPI_SLP, ATMEL_SPI_IRQ, ATMEL_I2C_SDA, ATMEL_I2C_SCL);
#elif MBED_CONF_APP_RADIO_TYPE == MCR20
#include "NanostackRfPhyMcr20a.h"
NanostackRfPhyMcr20a rf_phy(MCR20A_SPI_MOSI, MCR20A_SPI_MISO, MCR20A_SPI_SCLK, MCR20A_SPI_CS, MCR20A_SPI_RST, MCR20A_SPI_IRQ);
#elif MBED_CONF_APP_RADIO_TYPE == NCS36510
#include "NanostackRfPhyNcs36510.h"
NanostackRfPhyNcs36510 rf_phy;
#endif //MBED_CONF_APP_RADIO_TYPE
#if MBED_CONF_APP_MESH_TYPE == MESH_LOWPAN
LoWPANNDInterface mesh;
#elif MBED_CONF_APP_MESH_TYPE == MESH_THREAD
ThreadInterface mesh;
#endif //MBED_CONF_APP_MESH_TYPE
//RTC setup
time_t tim = 1497447150; //seconds from 1 january 1970
uint32_t wkup_delay = 15; //wakeup period in seconds from 1s to 36h
//Sensors setup
I2C i2c2(PF_0,PF_1); //pf0=d68 - i2c B sda , pf1=d69 - i2c B scl
SensorCollection sensors(i2c2);
// Setup UDP socket
NetworkInterface * network_interface;
UDPSocket sock;
uint16_t portUDP = 12500;
int ret = 0;
SocketAddress serv_addr(".....",portUDP); //my comp
Thread readout(osPriorityRealtime);
#define RDT_SIG 0x20
InterruptIn button(PC_13);
//README
//uC is in deepsleep waiting for 2 IRQ
//RTC wakeup and irq (pin PD_15) from radio
//RTC irq -> readout -> sleep
//radio irq -> some maintenance action with rf -> sleep
void rtc_handler(void){
readout.signal_set(RDT_SIG);
void rtc_initialization(){
rtc_init();
rtc_write(tim);
rtc_set_wake_up_timer(wkup_delay);
rtc_set_irq_handler((uint32_t)rtc_handler); //setup handler for irq
void socket_initialization(NetworkInterface * interface){
network_interface = interface;
sock.open(network_interface);
sock.bind(serv_addr);
void readout_thread(){
while(true){
Thread::signal_wait(RDT_SIG);
printf("WAKEUP!, timestamp: %lu \n", rtc_read());
printf("Sensors readout \n");
sensors.SensorCollectionReadout();
ret = sock.sendto(serv_addr, sensors.json_buffer, strlen(sensors.json_buffer));
if (ret <= 0){
printf("Error with socket sendto: %i\n", ret);
deepsleep(); //DEEPSLEEP CALL
mbed_trace_init(); //start mesh iterface
mbed_trace_print_function_set(trace_printer);
printf("\n\nConnecting...\n");
mesh.initialize(&rf_phy);
if(mesh.connect()){
printf("Connection failed!\n");
while (NULL == mesh.get_ip_address()) Thread::wait(500);
printf("connected. IP = %s\n", mesh.get_ip_address());
printf("MAC = %s\n", mesh.get_mac_address());
sensors.SetRtcTime(0x30,0x42,0x8,0x04,0x29,0x06,0x17); //in BCD code
socket_initialization(&mesh);
readout.start(readout_thread);
button.fall(rtc_handler);
rtc_initialization();
Also I've tried to put a deepsleep() in rtos idle thread like this, to make sure that all scheduled threads could perform:
rtos
void idle_thread(){
deepleep();
int main(void){
rtos_attach_idle_hook(idle_thread);
but then microcontroller cannot be woken up from deepsleep.
How can I make communication possible in my low-power application? I have tried almost everything. I will be very grateful for help. Please, list me things to try in my program.
Best regards, Wojciech Rzepecki
