8 years, 7 months ago.
Compile Dot-AT-Firmware?
Hi all,
I'm trying to compile Dot-AT-Firmware using online compiler, but no luck at all. After import library (libxDot), linker error "Error: Symbol operator delete (void*) multiply defined (by mbed_retarget.o and retarget.XDOT_L151CC.o)." keep showing. Any help or suggestion is appreciated.
Thanks in advance, aleksa
8 years, 4 months ago.
Make sure that you're using the exact same version of mbed OS that is mentioned in the libxdot commit message. The library is statically linked, so it needs the mbed OS version that it was linked against.
8 years, 5 months ago.
same here... can someone do his job and compile at least ONCE before throwing that on the internet ?!!!! Come on Guys !!!
