8 years, 8 months ago.
I want to use TLS / SSL on LPC1768 mbed
I face a problem on using TLS / SSL with LPC1768 Ethernet.
I import the following sample program but I get an error "Operator new out of memory". https://developer.mbed.org/teams/sandbox/code/http-example/
I guess the it is tested on K64F with Ethernet and NUCLEO_F411RE with ESP8266 only. My used series is not supported? What gives me this problems?
I'm looking forward to your answer. Thank you very much.
8 years, 6 months ago.
The error message tells everything: insufficient memory to use TLS.
I don't know the details of the MCU and how you use TLS but I suspect that public key cryptography in a TLS handshake causes the problem. Public key cryptography such as RSA are heavy for MCUs.
TLS-PSK (RFC4279) solves the problem but it would be troublesome. I recommend to use ESP32.
LPC1768 only has 32K of RAM available for user space application. I don't think it's enough for TLS handshake...
posted by Jan Jongboom 29 Aug 2017Thank you very much for your reply.
posted by Akira Kashihara 11 Sep 2017
