8 years, 9 months ago.
Valid "features_add" and "features_remove" .json values for compile config system
I've been looking at the compile config system in mbed-os. I notice there's a couple of variables in the .json files for the target override dict called "features_add" and "features_remove".
Is there a full list of the valid inputs that these can take anywhere and the actual associated src sub-directories that are added/removed from compilation as a result? Where possible I'd like to strip out everything from mbed-os that I don't need for my project.
I couldn't see anything in the relevant handbook section.
Thanks
Paul
8 years, 8 months ago.
Hi Paul,
You are correct that we have not documented the allowed features. I created a pull-request to our documentation to do just that. So that you get the information as fast as possible, please see the answer to your question here: https://github.com/ARMmbed/Handbook/pull/190
You can view the rendered diff at this url: https://github.com/ARMmbed/Handbook/pull/190/files?short_path=ec724f3#diff-ec724f3eef1ebfaec0a82e85061587c5
Thanks
Jimmy
