8 years, 8 months ago.
Web server without SD card
Hi all,
have somebody try to create web server without SD card? i found the example code but using SD card. I need information where the HTML code will be saved it if without SD card? Thank you
7 years, 2 months ago.
Sorry for the late reply. You can implement a web server without an sd card. Instead, the program should include the HTTP code. There is no code implemented in mbed, but there is code that implements the web server without the sd card in the keil project. https://github.com/Wiznet/W7500
W7500x_Library_Examples / Projects / Peripheral_Examples / WZTOE / httpServer / See section.
