8 years, 8 months ago.
UART - Nucleo STM32F411
Hi Guys i have problem with Nucleo using Serial or BufferSerial (similar test done with arduino it work without problem but in Nucleo Stm32F411Ret6 not)
i connected one (Nucleo1) STM32F411RET6 in PC another one (Nucleo2) STM32F411RET6 connected to the first ones via 5V / GND and D2/D8 (UART TX,UART RX) see picture for description
/media/uploads/Valoni/uar2nucleo.png
Code used to Nucleo1 is
**/* Nucelo 1 - code */**
#include "BufferSerial.h"
Serial PC(USBTX, USBRX);
BufferSerial Device(PA_9, PA_10);
	PC.baud(57600);
	Device.baud(57600);
	while(true)
		if (Device.readable())
			while (Device.readable())
				uint8_t MyValues = Device.getc();
				if (MyValues == 13)
					PC.printf("\n\n");
					PC.printf("%02x,", MyValues);
				else
		wait_ms(50);
Code used to Nucleo 2 is
/* Nucleo 2 - code */
	Device.baud(57600);
	uint8_t cmd1[] = { 0x0d, 0xaa, 0x01, 0x00, 0x00, 0x00, 0x27 };
	uint8_t cmd2[] = { 0x0d, 0xaa, 0x01, 0x02 };
	uint8_t cmd3[] = { 0x0d, 0xaa, 0x01, 0x00,  0x27 };
	uint8_t cmd4[] = { 0x0d, 0xaa, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x27 };
	while(true)
		Device.write(cmd1, sizeof(cmd1), 0, 0);
		wait_ms(50);
		Device.write(cmd2, sizeof(cmd2), 0, 0);
		wait_ms(50);
		Device.write(cmd3, sizeof(cmd3), 0, 0);
		wait_ms(50);
		Device.write(cmd4, sizeof(cmd4), 0, 0);
		wait_ms(50);
But it give me wrong results (or i missing something) like below : ???
instead to receive in Serial Monitor results
0x0d, 0xaa, 0x01, 0x00, 0x00, 0x00, 0x27,
0x0d, 0xaa, 0x01, 0x02,
0x0d, 0xaa, 0x01, 0x00, 0x27,
0x0d, 0xaa, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x27,
I receive something like :
0x0d, 0x00, 0x00, 0x00, 0x01, 0x1f,0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x27, 0x27, 0x27, 0x27, 0x27, 0x27 0x27, 0x27, 0x27 0x27, 0x27, 0x27 0x27 0x27,0xaa,0xaa .... (one long row until i get another 0x0d which start with new line)
Could you try a faster baudrate (115200) and also increasing the value of wait_ms between the .write. Note: For the Nucleo2 you don't need BufferedSerial work only with Serial, you are only sending.
Best regards
posted by Felícito Manzano 10 Jul 2017
I need to use that speed of communication with other devices but i face problem that i tried to simulate with nucleo 2
(similiar test on arduino work as well it could read from nucleo2 info without problem)
posted by VALON HOTI 11 Jul 2017
Problem resolved in non usually way with change of hardware clock *for uart port only so the code belove work without problem as READER.
   reader is resolved in this way
Serial myDevice(PA_9, PA_10);
int i = 0;
uint8_t MyInfo;
bool myCondiyion = false;
uint8_t buffer[14];
void interrupt();
    pc.baud(57600);
    pc.printf("Hello World !\r\n");
    pc.printf("CPU SystemCoreClock is %d Hz\r\n", SystemCoreClock);
    pc.printf("PCLK1 is %d Hz\r\n", HAL_RCC_GetPCLK1Freq());
    pc.printf("PCLK2 is %d Hz\r\n", HAL_RCC_GetPCLK2Freq());
    pc.printf("RCC_CFGR is 0x%08X\r\n", RCC->CFGR);
    RCC->CFGR &= ~0x0000E000;  // PPRE2, Bit 15-13
    RCC->CFGR |=  0x00008000;  // PPRE2: PCLK2 = AHB / 2
    myDevice.baud(57600);
    myDevice.attach(&interrupt, Serial::RxIrq);
    while (1)
        if (myCondiyion == true)
            for (int j = 0; j <14; j++)
                /* trego gjendjen e bufferit */
                pc.printf("0x%02x,", buffer[j]);
            memset(buffer, 0, sizeof(buffer) / sizeof(buffer[0]));
             i = 0;
             pc.printf("\n");
void interrupt()
    MyInfo = myDevice.getc();
    if (MyInfo == 13)
        myCondiyion = true;
        i=0;
        buffer[i] = MyInfo;
    else
        i++;
        buffer[i] = MyInfo;
posted by VALON HOTI 26 Jul 2017
SENDER now is defined in this way too
/* sender is resolved in this way */
    pc.baud(57600);
   //Trego gjendjen e kllokun systemor para ndryshimit
    //Beni ndryshimet
    //Trego gjendjen e kllokun systemor pas ndryshimet
    /* percakto nje levizje */
    while(true)
        myDevice.write(cmd1, sizeof(cmd1), 0, 0);
        wait_ms(50);
        myDevice.write(cmd2, sizeof(cmd2), 0, 0);
        wait_ms(50);
        myDevice.write(cmd3, sizeof(cmd3), 0, 0);
        wait_ms(50);
        myDevice.write(cmd4, sizeof(cmd4), 0, 0);
        wait_ms(50);
what is strange is this part of code for changing clock of uart communication droping it on half this one helped me to have good communication between devices
   /* part which resolved problem */
this part was been resolved into :
https://developer.mbed.org/questions/54029/USART-Problem-with-NucleoF401RE/
Assigned to VALON HOTI 8 years, 7 months ago.
