8 years, 9 months ago.
Multiple controllers on my arcade cabinet won't default to Pinscape controller for Visual Pinball
Hello, I have multiple devices (controllers) on my arcade cabinet. The problem is when I play Visual Pinball, it doesn't use the Pinscape controller as default controller (analog plunger, Using optical lin. array). Is there anything I can do (add a script in pinscape software or even RocketlauncherUI) to make this work instead of maually disconnecting all other controllers just to play VP?
Thanks, Thomas
