8 years, 3 months ago.
LiPo charger MCP73831 does not light an LED with it's STAT pin when done charging
3 down vote favorite
I'm trying to charge a LiPo with MCP73831 with 2 LEDs for status. I have an amber LED D1 which is on when VUSB is getting power from the USB connector, which means that it's charging. And a green LED D2 that should also light up when the battery is fully charged.
Here is the date sheet: http://www.componentschip.com/details/Microchip-Technology/MCP73831EV.html
I'm having no luck getting the green LED D2 to light up when the charge is complete. I can see that the USB draw drops to near zero, and after being plugged into USB power for hours, the green LED will never light up. It's clearly done charging and the battery output voltage measures 4.2V, which is expected for a fully charged single cell LiPo battery.
Interestingly, when I poked around with the multimeter I got the green LED to illuminate. When I measured the voltage between GND and VBAT the green LED turned on while the probes were in contact with the circuit. When I removed the multimeter probes, the green LED immediately turned off.
So two questions:
Why doesn't the STAT pin output HIGH when charging is complete as the datasheet claims it should? (which should light the green LED D2) Why does measuring the voltage between GND and VBAT cause the STAT pin to output HIGH? Does the multimeter measuring between GND and VBAT effectively place a high Ohm resistor between the two? And if so, would that fix this? Why?
