8 years, 8 months ago.
Need a driver for ILI9481 GLCD
Hi all, I have just bought a Graphical LCD Display from Banggood,
and I cannot find any WORKING code for it,
I want to use LPC1549 Xpresso board, or LPC812. because of the footprint.
I have searched, extensively, but there doesn't seem to be any actual code for this driver IC.
I would relay like to get this going .
Thanks
Ceri
Hello Ceri,
Is it an ILI9841 or rather an ILI9481 (like this one)? In case it's an ILI9481 then there is a driver available here.
Thanks, I think I found this befor, BUT i have found a reference to ILI9481,
Although There doesn't seem to be a main.c for this ???
Do you have one ???
Cheers
Ceri
posted by 20 Jun 2017Unfortunately a do not have access to such display but I would try the UniGraphic demo adapted as follows:
main.cpp
#include "stdio.h"
#include "string"
#include "Arial12x12.h"
#include "Arial24x23.h"
//#include "Terminal6x8.h"
#include "Arial43x48_numb.h"
#include "pict.h"
#include "pavement_48x34.h"
#include "TFT_MIPI.h"
Serial pc(USBTX, USBRX);
TFT_MIPI myLCD(SPI_8, 20000000, PA_7, PA_6, PA_5, PB_6, PA_8, PA_9,"myLCD"); // SPI 8bit, 20MHz, mosi, miso, sclk, cs, reset, dc for F103RB
//TFT_MIPI myLCD(PAR_16, PortC, PH_0, PH_1, PA_0, PA_1, PA_4,"myLCD"); // Parallel 16bit, Port, CS, reset, DC, WR, RD for F401
Timer t;
unsigned short backgroundcolor=Black;
unsigned short foregroundcolor=White;
char orient=1;
// myLCD.set_contrast(26);//for uc1608
// myLCD.set_contrast(46);//for ist3020
myLCD.set_orientation(orient);
int time, time2;
pc.baud (115200);
pc.printf("\n\nSystem Core Clock = %.3f MHZ\r\n",(float)SystemCoreClock/1000000);
t.start();
8 years, 6 months ago.
Hello to all, I have the same problem; the display pins are: LCD_RTS, LCD_CS, LCD_RS_ LCD_WR, LCD_RD, not SPI interface is needed but parallel 8bit I think. For example.. I tried to modify the code by configuring it according to my pins TFT_MIPI myLCD(BUS_8, PortC, PB_0, PC_1, PA_4, PA_1, PA_0,"myLCD"); Parallel 8bit, Port, CS, reset, DC, WR, RD for F446
I did not find anything useful to be able to run the module, so are there novelties on your part?
Thank you very much
Hello Federico,
I don't have access to such display but I would suggest to try the following:
... TFT_MIPI myLCD(PAR_8, PortC, PH_0, PH_1, PA_0, PA_1, PA_4,"myLCD"); // Parallel 8-bits, Port, CS, reset, DC, WR, RD for F446 ...
Wiring:
| ILI9481 module | NUCLEO-446RE board | |||
| LCD_D0 | <=> | PC_0 | ||
| LCD_D1 | <=> | PC_1 | ||
| LCD_D2 | <=> | PC_2 | ||
| LCD_D3 | <=> | PC_3 | ||
| LCD_D4 | <=> | PC_4 | ||
| LCD_D5 | <=> | PC_5 | ||
| LCD_D6 | <=> | PC_6 | ||
| LCD_D7 | <=> | PC_7 | ||
| LCD_RST | <=> | PH_1 | ||
| LCD_CS | <=> | PH_0 | ||
| LCD_RS | <=> | PA_0 | ||
| LCD_WR | <=> | PA_1 | ||
| LCD_RD | <=> | PA_4 |
See below.
posted by Zoltan Hudak 19 Jun 2017Just adding this hear .. I Finally got the screen to work, on a NUCLEO L 152
<code> PinName buspins[8]={D8,D9,D2,D3,D4,D5,D6,D7};
int main() { confSysClock(); Configure system clock (72MHz HSE clock, 48MHz USB clock)
tft = new ILI9341(BUS_8, buspins ,A3, A4, A2, A1, A0, "tft",320,480);
</code>
Not quit as fast as I hoped for graphics, but this is only the second day playing with a non NXP part.
posted by ceri clatworthy 11 May 2018
