8 years, 6 months ago.
Serial class as a member of my custom class
Hello, I have a problem with inicilization of class in another class. Here is my constructor:
PpmIn::PpmIn(PinName pin): ppm(pin), pc_com(USBTX, USBRX)
    pc_com.printf("Constructor say hi!");
    current_channel = 0;
pc_com is initialized in header file like this:
protected:
        Serial pc_com;
        InterruptIn ppm;
I think, that there shouldn't be a problem, but I always end with this error: Error: "mbed::Stream::Stream(const mbed::Stream &)" (declared at /extras/mbed-os.lib/drivers/Stream.h:68 is inaccessible in "extras/mbed-os.lib/drivers/Serial.h", Line: 52, Col: 43
Similar problem was discussed here: https://developer.mbed.org/forum/helloworld/topic/2771/
It seems, that I can't access constructor in mbed::Stream? Really? Do you know how to get over this? Thank you very much.
edy05
Hello Eduard,
That's strange because the following compiled for me with no errors:
PpmIn.h
class PpmIn
public:
    PpmIn(PinName pin);
protected:
    InterruptIn  ppm;
    Serial       pc_com;
PpmIn.cpp
#include "PpmIn.h"
PpmIn::PpmIn(PinName pin): ppm(pin), pc_com(USBTX, USBRX) {
main.cpp
#include "PpmIn.h"
PpmIn myPpm(PA_9);
int main(void) {
    while(1) {}
Did you include the header files?
Strange. Could you please look at the full code here? https://developer.mbed.org/users/edy05/code/pwm-output/ I don't see any difference there.
posted by Eduard Medla 09 Jun 2017
It seems that you are using the same name for the PinName ppmIn (line #7) as for the PpmIn ppmIn object (line #25). The code compiles smoothly after commenting out line #7, uncommenting line #18 and modifying line #25 as follows:
    PpmIn ppmIn(D14);
posted by Zoltan Hudak 09 Jun 2017
Hello Zoltan, Yes, now it work, thank you
posted by Eduard Medla 13 Jun 2017
