8 years, 10 months ago.
Heap allocation error
Hi, I'm using sd-driver https://github.com/ARMmbed/sd-driver library with mbed-connector to read and write sd files with the cloud and my platform is K64F. I'm not sure if my problem is related to this library but I tried to remove the sd read/write functions and libraries and everything worked fine. Here is my problem: After compiling and running the code it works fine but after a few minute, I got the error "Operator new out of memory" in the terminal. I'm using these two functions to read and write to sd. (I removed the other part of the code)
#include "security.h"
#include "easy-connect.h"
#include "simple-mbed-client.h"
#include <stdio.h>
#include <cstdlib>
#include "C12832.h"
#include "LM75B.h"
#include "MMA7660.h"
#include <cstring>
#include <string>
#include <sstream> //for conversion of data types to string
#include <iomanip> //for setting precision of float
#include "FATFileSystem.h"
#include "SDBlockDevice.h"
#include <errno.h>
/* mbed_retarget.h is included after errno.h so symbols are mapped to
* consistent values for all toolchains */
#include "platform/mbed_retarget.h"
SimpleResourceString SDcard_write = client.define_resource("device/0/SD_W", "RED", M2MBase::GET_PUT_ALLOWED, true, &SD_write_updated);
SimpleResourceString SDcard_read = client.define_resource("device/0/SD_R", "RED", M2MBase::GET_ALLOWED, true);
void SD_write_updated(string new_value)
printf("device/0/name changed to:\r\n");
printf("%s\r\n", new_value.c_str());
sd_write=true;
sd_write_value=new_value;
void SD_read_updated(void* args){
printf("Reading from SD Card...\r\n");
sd_read=true;
void sd_write_open()
string str2;
// char *y;
// int size=128;
// char *y =(char *)malloc(size);
string sub="\\n"; // str2 is string to search, sub is the substring to search for
vector<size_t> positions; // holds all the positions that sub occurs within str
size_t pos = sd_write_value.find(sub, 0);
while(pos != string::npos) {
positions.push_back(pos);
pos = sd_write_value.find(sub,pos+1);
for(int i=0; i<positions.size(); ++i) {
printf("list the posistions %d\n",positions[i]);
// printf("sd_write_value size is %d\n",sd_write_value.size());
printf("Writing to Sd card...\n");
FILE* fd = fopen("/sd/mydir/out.txt", "w+");
errno_error(fd);
for(int i=0; i<=positions.size(); i++) {
if(i==0) {
str2= sd_write_value.substr(0,positions[i]);
} else if (i==positions.size()) {
str2= sd_write_value.substr(positions[i-1]+2,sd_write_value.size());
} else {
str2= sd_write_value.substr(positions[i-1]+2,positions[i]-(positions[i-1]+2));
// y=str2.c_str();
// char *y = &str2[0u];
printf("here is the %d line: ",i);
printf("%s\n",str2);
fprintf(fd, "%s\n", str2);
fclose(fd);
printf("Done");
void sd_read_open()
string sum;
printf("Reading file at /sd/mydir/in.txt\n");
FILE *fp = fopen("/sd/mydir/in.txt", "r");
char buffer [128];
size_t i=0;
while (!feof(fp)){
bool ret = (fgets(buffer, 64, fp)) ;
if(ret)
sum.append(buffer);
printf("Here is the %d line:",i);
printf ("%s\n", buffer);
i++;
SDcard_read=sum;
// printf("Here is the sum: \n");
// printf("%s\n",sum);
fclose(fp);
Any help would be appriciated.
