8 years, 9 months ago.
What would be the best way to change the Android heart rate monitor from the ECG chip to the optical
In my application, the MAX32620HSP is going to be wrist mounted. It is not feasible to attach the leads to a chest strap, so I wish to change the Android app heart rate monitor to the optical chip instead of the ECG one. What would be the easiest/best way to change the code in both the FW and the app so that the heart rate displayed would be from the optical chip instead of the ECG?
Thanks
Glenn
MAXREFDES100# Health Sensor Platform
Could you do this ?
posted by ANIL TIRLIOGLU 13 Sep 2017
Hello Glenn,
Currently there is not an algorithm within the HSP FW to convert the raw optical data into a heart rate value. In the following link under "Design Resources", there is a mbed project that contains an algorithm that could be tailored for the MAX30101 optical chip on the HSP.
https://www.maximintegrated.com/en/design/reference-design-center/system-board/6300.html/tb_tab2
Once the heart rate value is obtained, via the algorithm, one could transmit this instead of the ECG value, or add an additional characteristic that contains the value.
Jerry Bradshaw - Maxim Integrated Products
Could you do this ?
