8 years, 9 months ago.
mbed assertation failed: 0 == ret in /NanostackInterface.cpp,
I am following this tutorial about the mbed-os example with mbed client :
https://github.com/ARMmbed/mbed-os-example-client
Things like working on both border router and client sides,
However, it’s often to get this assert message after running the application a while:
mbed assertation failed: 0 == ret, file: ../mbed-os/features/nanostack/FEATURE_NANOSTACK/nanostack-interface/NanostackInterface.cpp, line 213
And obviously the client stops to working after this message. It is annoying.......
Could you guys suggest a solution?
Thanks in advance
Haisheng
Ps: here is the debug message:
Starting mbed Client example...
Using Mesh
Connecting to Mesh..
Connected to Network successfully
IP address 2a01:e35:2f47:b380:xxxx:xxxx:xxxx:
SOCKET_MODE : UDP
Connecting to coaps:[2607:f0d0:2601:52::20]:5684
Registered object successfully!
led_execute_callback pattern=500:500:500:500:500:500:500
Resource: 3201/0/5850 executed
Payload:
Payload:
Payload:
Payload:
Payload:
